Michael_Gia Posted October 1, 2024 Share Posted October 1, 2024 Hey, anyone else getting this? I keep getting this error even after I verify, make available, and whatever else to my product key. Link to comment Share on other sites More sharing options...
DRAWZILLA Posted October 1, 2024 Share Posted October 1, 2024 I get something like that when trying to save it, sent it in to T.S. but they couldn't tell me why this was happening. I usually have to shut down and re-start to get rid of it. funny thing is it still saves the plan but says it can't save the plan in the message. Link to comment Share on other sites More sharing options...
Michael_Gia Posted October 1, 2024 Author Share Posted October 1, 2024 2 hours ago, DRAWZILLA said: funny thing is it still saves the plan but says it can't save the plan in the message. Thanks for saying that. I just checked and the plan was indeed saved with the most recent changes despite the error message. I restarted and it seems to work so far. I did have to deactivate and reactivate the product key. Link to comment Share on other sites More sharing options...
CarrieS Posted October 2, 2024 Share Posted October 2, 2024 With the MacOS Sequoia update, a feature called Private Wi-fi address may cause issues with activation or authentication if you're connected to a network wirelessly.https://support.apple.com/en-us/102509 If you are continuously prompted to activate you may need to turn this feature off for any wireless networks you connect to. Carrie Link to comment Share on other sites More sharing options...
Rosco2017 Posted October 2, 2024 Share Posted October 2, 2024 I work from home and an office and I get this message everyday. Called Chief Tech Support and they helped me change the settings but It still persists. So for now I make sure I go into my digital locker and deactivate my license and reactivate it whenever I move from office to office. That seems to be an annoying but reliable fix. Link to comment Share on other sites More sharing options...
Solution CarrieS Posted February 11 Solution Share Posted February 11 Hi, Chief Architect has a program update available to resolve the activation issue introduced in Mac OS Sequoia (Mac OS version 15). This patch applies to Chief Architect X16 and Home Designer 2025 products. Prior to installing this update, you will first need to deactivate your software. After the patch is installed, the software will activate on your computer and resolve the activation issue caused by changing Wi-Fi networks. Please note that after the patch is installed, X16 and Home Designer 2025 will be using different identifiers than prior versions so if you switch between this version and an earlier version (like X15 or Home Designer 2024) you will need to deactivate. Patch Installation Instructions: Sign in to your Chief Architect Account: https://accounts.chiefarchitect.com/digital-locker Click on the "MAKE AVAILABLE" button under your product key. Click the "DOWNLOAD" link. Choose "Mac" then download and install the patch. If you have any questions about the process please contact our Technical Support team. Carrie 1 1 Link to comment Share on other sites More sharing options...
Michael_Gia Posted February 12 Author Share Posted February 12 On 10/2/2024 at 1:31 PM, Rosco2017 said: I work from home and an office and I get this message everyday. Called Chief Tech Support and they helped me change the settings but It still persists. So for now I make sure I go into my digital locker and deactivate my license and reactivate it whenever I move from office to office. That seems to be an annoying but reliable fix. It's fixed now. 1 Link to comment Share on other sites More sharing options...
