JKEdmo Posted 9 hours ago Share Posted 9 hours ago Good morning, I have a mulled window unit with 2 single casements below and a fixed unit above. All on same level. I want window shutters on the lower units only (shown in red below), but have not had luck. Is there a particular technique within the windows / shutters setting, or is this condition too unusual and I should just place the shutters manually as symbols? Thanks again, Jim Link to comment Share on other sites More sharing options...
Solution DBCooper Posted 9 hours ago Solution Share Posted 9 hours ago You should just be able to add shutters to the mulled unit and then adjust the height and width to be what you want. Link to comment Share on other sites More sharing options...
JKEdmo Posted 8 hours ago Author Share Posted 8 hours ago 32 minutes ago, DBCooper said: to the mulled unit and then adjust the height and width to be what you want Sure enough! Thanks DB. Jim Link to comment Share on other sites More sharing options...
joey_martin Posted 8 hours ago Share Posted 8 hours ago However....architecturally the shutters should match the width of the windows. Small shutters on large windows = no no. Link to comment Share on other sites More sharing options...
