Treehouse2339 Posted September 19, 2024 Share Posted September 19, 2024 The issue I have is that when I take the proposed floorplan to a layout page and print to PDF, the proposed floorplan line weights is very heavy so that is is not legible. I turned them off prior to sending them to layout. Likely a silly setting that caused this, but I have been trying to find the issue for 3 hours and thought I would see if someone can help. Thanks in advance. Link to comment Share on other sites More sharing options...
MPDesign Posted September 19, 2024 Share Posted September 19, 2024 Look at the drawing sheet setup and see what the line weight setting is. Link to comment Share on other sites More sharing options...
AvoyeDesign Posted September 19, 2024 Share Posted September 19, 2024 5 hours ago, MPDesign said: Look at the drawing sheet setup and see what the line weight setting is. To expand on this, @Treehouse2339the simple solution is to make sure your plan and layout settings match. Link to comment Share on other sites More sharing options...
