NatalyJ Posted September 17, 2024 Share Posted September 17, 2024 I am unsure why the Perspective Overviews have a blank white space when I go to those views. That is the case with this particular plan; my other plans work when going to these views. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted September 17, 2024 Share Posted September 17, 2024 It could be that the model is at an extreme elevation. It's best to have the 1st floor at 0.00 elevation Link to comment Share on other sites More sharing options...
Hammer7 Posted September 17, 2024 Share Posted September 17, 2024 Also, when in doubt turn all layers on in your camera view and make sure you have the correct layer set for 3D. Link to comment Share on other sites More sharing options...
DBCooper Posted September 17, 2024 Share Posted September 17, 2024 If all the layers are on and you can't see anything, it could be that your plan has something in it that is very far from the rest of the plan. The overview cameras always center on whatever is in the model so stray objects can cause problems. If the normal perspective camera works, then this is probably what is happening. If you can't figure it out, then you should post the plan. Link to comment Share on other sites More sharing options...
