Style Palette: Door Hardware and Handle Material Change Not Possible
ValleyGuy
I need a nudge in the right direction. I decided to give style palettes a try and isolated it down to only base boards and door materials. I just want to change the materials - no features. Base boards worked fabulously, however, I can not seem to get the door hardware and handle to change. I even selected every line property option available with no success. Is there a way to change the hardware and the handle materials?
@scottharris Hi Scott, thanks for replying. I should have given more information, it is an interior door. Here is a picture with all the selections chosen. It appears proper in the thumbnail on the right, but not in the plan when applied.
I just created a second style palette and tried applying it.... and received the same result.
I'm still at a loss to get the handle to change using a style palette. I just used the material painter on the handle as a work around but would like to use only the style palette if possible. Any other suggestions???
