Wall Niche
Charlenerene
Go to solution Solved by scottharris,
Char. , Robert's post is just a standard plan you can open as normal , then you can copy and paste between plans or save the items in the plan to your User Library and then use them when needed.
if you haven't seen it yet ,you have inspired Joe to start making a Niche Library too ...thanks :)
https://chieftalk.chiefarchitect.com/index.php?/topic/4358-wall-niche-symbol-library/
