para-CAD Posted July 5, 2024 Share Posted July 5, 2024 I searched for "Sloped Insulation" and there was nothing so here is my question. How do I make the batt insulation slope like in the attached picture? I have never found a way to get the box to break so I could slope it. Too bad a generic batt insulation hatch couldn't be a fill in a regular polyline...problem solved. Link to comment Share on other sites More sharing options...
Kbird1 Posted July 7, 2024 Share Posted July 7, 2024 On 7/5/2024 at 11:09 AM, para-CAD said: I have never found a way to get the box to break so I could slope it. It's always been this way as far as I know, the Insul. Fill is a "Special Fill" from what I've read previously and only works in Chief's rectangular / square Insul. Boxes. I usually make a copy and make it shorter and rotate parallel to the roof plane, it's bit messy looking but when it's all you've got.... I guess if you really needed them you could Drawn them , and save to the library , but you would need a block for each pitch. M. 1 Link to comment Share on other sites More sharing options...
glennw Posted July 7, 2024 Share Posted July 7, 2024 I have an insulation fill like this if it fills the bill. You can shape the polyline and have all the normal fill parameters available so that you can play around with the scale to make it fit full height in the polyline. The sloping bit will always cut the fill though. 1 Link to comment Share on other sites More sharing options...
