JosephSchloss Posted Thursday at 11:44 PM Share Posted Thursday at 11:44 PM Hello everybody, Can anyone help out? This is a full height Basement (Floor Level is -94") with one room being even Lower (Floor Level -154") Two Problems: 1. I couldn't delete that wrap around under the full Basement. 2. That wall shown here on the right of the Picture needs to be stepped butt he system will either lower or raise the whole wall and will not allow me to step as required. Thanking in advance for any suggestion/help/etc. Link to comment Share on other sites More sharing options...
DBCooper Posted Friday at 04:28 PM Share Posted Friday at 04:28 PM 1. Not sure what that is. Probably should post the plan and someone will be able to figure it out. 2. Sounds like you need to add a "break" to the wall. While in an elevation view looking at the wall, you can add a break point along the top or bottom and then drag the wall up or down and it should only move the one part. This tech article might help: https://www.chiefarchitect.com/support/article/KB-01809/creating-a-stepped-foundation.html Or this video: https://www.chiefarchitect.com/videos/watch/402/stepping-a-foundation.html?playlist=88 Link to comment Share on other sites More sharing options...
JosephSchloss Posted 2 hours ago Author Share Posted 2 hours ago Hello, Thanks for taking the time to review my Post. I'm attaching the Plan here, It's drawn on x11 For Problem 1. Open the Plan & generate a 3D you will see the Issue right away. For Problem 2. I know I need a Wall break and that's what I actually did, but when starting to Drag up that broken wall segment, the system automatically reconnected all segments of the Wall into one. Pls review. Thanks in advance for your time and will to help!!! Hope you come up with a solution! Pls note; I'm with CA from 2017 x8 so don't hesitate to get into decaled commands. Wishing you all the Best. 220 for Post.plan Link to comment Share on other sites More sharing options...
