Mackenzie Posted July 2, 2024 Share Posted July 2, 2024 Hello, I'm trying to represent a crewed in porch by changing a single one window into a screen but when I apply the screen to the glass pane it becomes Luminous and no longer see through, do you know why that is or if there is a better tool for created a screened in room in Chief architect? based on the material selector it looks like this should work but I'm getting effectively getting a new light source instead, I've tried adjusting and turning off the sun but that didn't seem to make a difference. Thank you in advance for any help! Link to comment Share on other sites More sharing options...
Solution Designers_Ink Posted July 2, 2024 Solution Share Posted July 2, 2024 Use the rainbow tool on the screen material. Then go to Properties and make sure your Emissive is set to 0. It might just barely have any, but set it to zero. You can then adjust the transparency in the same tab to fit what look you are going for. See if that helps any. 1 Link to comment Share on other sites More sharing options...
Mackenzie Posted July 2, 2024 Author Share Posted July 2, 2024 That was exactly what I needed, thank you for the help! Link to comment Share on other sites More sharing options...
Kbird1 Posted July 3, 2024 Share Posted July 3, 2024 That particular Screen Material is actually a Linen from the Fabric Library, if you do a Forum search of Window Screen you should find several Materials that people have uploaded for screen porches. M. Link to comment Share on other sites More sharing options...
SNestor Posted July 3, 2024 Share Posted July 3, 2024 Or…just get my Screened Porch Library. https://www.mychiefskills.com Link to comment Share on other sites More sharing options...
Mackenzie Posted July 8, 2024 Author Share Posted July 8, 2024 On 7/3/2024 at 3:51 PM, SNestor said: Or…just get my Screened Porch Library. https://www.mychiefskills.com I did end up doing this. It worked well, thank you Link to comment Share on other sites More sharing options...
SNestor Posted July 9, 2024 Share Posted July 9, 2024 Fantastic! Looks great. Link to comment Share on other sites More sharing options...
