Reeded Cabinet door
CAuserBarb
58 minutes ago, CAuserBarb said:
reeded
very challenging to do as you would need all door sizes in order to keep the reeds the same size when a cabinet is 24" wide vs 9" wide for instance. Best approach here is using a reeded material so that it is generative based on width
  • Upvote 2
  • 3 months later...
On 4/19/2024 at 10:23 AM, CAuserBarb said:
Anyone know of a specific Chief cabinet catalog that offers a reeded door style? similar to this one of WoodModes.
TIA!
As Rene said, Its very hard to model a door which will change the number of reeds when the size is changed. The best way is to make the frame and use a bump or a normal map to create the reed lines for the middle part. Because the material will get tiled when the door is stretched.
  • 4 months later...
I know this is an old thread but I was trying to figure it out myself and found a bit of a workaround... Thought I'd leave it here in case anyone else is looking for a solution :)
Tried the Alexandria door but as mentioned above, it looks terrible with multiple different sizes of doors/drawers.
This is what I do now:
Use the "Slim-Shaker" door from Cabinet Doors No. 2
Paint the center panel "Linear Narrow Glass" from Materials>Glass & Glazing>Textured Glass
Blend your cabinet colour with the linear glass. Then Adjust Material Definition to remove the transparency of the glass.
I've added it to some drawer fronts here - uniform through different widths:
