CAuserBarb Posted April 19, 2024 Share Posted April 19, 2024 Anyone know of a specific Chief cabinet catalog that offers a reeded door style? similar to this one of WoodModes. TIA! Link to comment Share on other sites More sharing options...
Renerabbitt Posted April 19, 2024 Share Posted April 19, 2024 58 minutes ago, CAuserBarb said: reeded very challenging to do as you would need all door sizes in order to keep the reeds the same size when a cabinet is 24" wide vs 9" wide for instance. Best approach here is using a reeded material so that it is generative based on width 2 Link to comment Share on other sites More sharing options...
Greg_NY61 Posted April 21, 2024 Share Posted April 21, 2024 I saw that style door the other day, I think it was in the latest Kemper Cabinets one of the styles is that door. Link to comment Share on other sites More sharing options...
Breeze_Design Posted August 15, 2024 Share Posted August 15, 2024 Plain & Fancy's "Alexandria" 2 Link to comment Share on other sites More sharing options...
ArmanChahal Posted August 17, 2024 Share Posted August 17, 2024 On 4/19/2024 at 10:23 AM, CAuserBarb said: Anyone know of a specific Chief cabinet catalog that offers a reeded door style? similar to this one of WoodModes. TIA! As Rene said, Its very hard to model a door which will change the number of reeds when the size is changed. The best way is to make the frame and use a bump or a normal map to create the reed lines for the middle part. Because the material will get tiled when the door is stretched. Link to comment Share on other sites More sharing options...
sea_lyons Posted December 20, 2024 Share Posted December 20, 2024 I know this is an old thread but I was trying to figure it out myself and found a bit of a workaround... Thought I'd leave it here in case anyone else is looking for a solution Tried the Alexandria door but as mentioned above, it looks terrible with multiple different sizes of doors/drawers. This is what I do now: Use the "Slim-Shaker" door from Cabinet Doors No. 2 Paint the center panel "Linear Narrow Glass" from Materials>Glass & Glazing>Textured Glass Blend your cabinet colour with the linear glass. Then Adjust Material Definition to remove the transparency of the glass. I've added it to some drawer fronts here - uniform through different widths: 1 1 Link to comment Share on other sites More sharing options...
