ChiefZachary Posted April 16, 2024 Share Posted April 16, 2024 Hi all, I am currently in the process of designing a barndominium, but I am having issues with my ceiling heights. The eave needs to be 14' which means my exterior walls need to be 14'. Once I have done this, when I try to create a interior room with a 9/10' ceiling, the wall height automatically changes to 9 or 10' to that specific room and throws my roof all out of whack. Any way to combat this? I am sure there is a way, but I am new at chief architect, so any help would be appreciated. Thank you! Link to comment Share on other sites More sharing options...
ChiefZachary Posted April 16, 2024 Author Share Posted April 16, 2024 I have upgraded to chief architect. Link to comment Share on other sites More sharing options...
Gawdzira Posted April 16, 2024 Share Posted April 16, 2024 It sounds like the best approach would be to make the room ceiling ht. 14' in order for that to be the plate height where the rafters/trusses bear. Then place a dropped ceiling at 9 or 10'. In the roof tools there is a "Ceiling Plane" tool. Place a ceiling plane and adjust accordingly. 1 Link to comment Share on other sites More sharing options...
Michael_Gia Posted April 16, 2024 Share Posted April 16, 2024 and turn off auto rebuild roof 1 Link to comment Share on other sites More sharing options...
Doug_N Posted April 16, 2024 Share Posted April 16, 2024 Should you want to move the roof to a different height than normal, then in the roof dialog box, raise the roof Then in the wall dialogue box Now the ceiling plates will be generated with normal birdsmouth, and the ceiling will be at the set height of 9" or whatever you like. The roof will still automatically be generated with all framing, and so will walls and ceilings. You will have to do some cad work for the ceiling rafters to show how they are supported by bracing between wall studs. 1 Link to comment Share on other sites More sharing options...
ChiefZachary Posted April 17, 2024 Author Share Posted April 17, 2024 I appreciate all the help. I will see what I can do with your solutions!! Link to comment Share on other sites More sharing options...
