RichardKn Posted March 26, 2024 Share Posted March 26, 2024 I have three dormers and each has no front wall, only a window floating on nothing. As a result, the adjacent room cannot be recognized as a room, except if I make an invisible wall separating off the dormer. The dormers also have no ceilings. I've experimented to no avail. Link to comment Share on other sites More sharing options...
TeaTime Posted March 26, 2024 Share Posted March 26, 2024 "No wall" makes me think there's no hole in the roof. Or that the roof is cutting the wall or something. Need more info to even make a proper guess though. Can you post the plan? Link to comment Share on other sites More sharing options...
RichardKn Posted March 27, 2024 Author Share Posted March 27, 2024 These are the files, the larger being the whole house. The smaller ones are views of the attic/second floor. Cussetta House Build 4a-Dormer View.dwg Cussetta House Build 4a-no furniture.dwg Cussetta House Build 4a-no furniture-all floors.dwg Link to comment Share on other sites More sharing options...
DBCooper Posted March 28, 2024 Share Posted March 28, 2024 I think it would be more helpful to post the actual ".plan" file. You need to make sure it is closed and you will probably need to zip it to make it small enough to upload. You might even need to delete stuff that has nothing to do with the dormers. Either that or post it on some other online location with a link here. 1 Link to comment Share on other sites More sharing options...
Garybills Posted April 16, 2024 Share Posted April 16, 2024 @RichardKnI downloaded the file but when I try to open in Chief it says no data. Link to comment Share on other sites More sharing options...
RichardKn Posted April 16, 2024 Author Share Posted April 16, 2024 Ok, I finally got the files to zip. The issue is the dormers on the second floor. I've tried several things, but none have worked well. I'd like to be able to have views of the front of the house look right, instead of weird as now. Thanks in advance for your help. Cussetta House Build 4b.zip Link to comment Share on other sites More sharing options...
RichardKn Posted April 19, 2024 Author Share Posted April 19, 2024 Hi Eric, No business, just designing my own house. I did listen to some of your YouTube videos. They are very good. Richard Link to comment Share on other sites More sharing options...
