Auto Dormer has no exterior end wall, only side walls
RichardKn
I have three dormers and each has no front wall, only a window floating on nothing.  As a result, the adjacent room cannot be recognized as a room, except if I make an invisible wall separating off the dormer.  The dormers also have no ceilings.  I've experimented to no avail.
I think it would be more helpful to post the actual ".plan" file.  You need to make sure it is closed and you will probably need to zip it to make it small enough to upload.  You might even need to delete stuff that has nothing to do with the dormers.  Either that or post it on some other online location with a link here.
  • 3 weeks later...
