Defauly wall/railing settings
MN_JohnH
It seems I can take a railing that I have made,  and make it so the default settings will be that of that railing, but how do I make a railing change to poses the current defaults?
Some things change automatically when you change the defaults but apparently railings do not. It seems like I should be able to click on the railing and tell it to change so that it will be the railing type that I have set in the defaults.
7 minutes ago, SNestor said:
Once you draw a wall...it will not change by just changing the default. (roofs are the same)
If you change the default...you will have to redraw the wall.
OK but say I have a bunch of wall drawn and I now I change the default, it would seem like there would be some way to select the wall and then change it so that it now takes on the properties of the default settings? This seems like it would be a pretty basic function.
Assuming you can remember the default wall type....
Group Select all the walls you want to change.
Open the Wall Specification dbx and change the Wall Type to match your default.
