RobWhite Posted March 21, 2024 Share Posted March 21, 2024 I am trying to plot in 3D framing a brace @ about 45º in plan view, but also rising @ about 6º in elevation (or on the 'Z' coordinate plane). (The is in steel framing) I am using 'convert polyline' to a molding, but cannot raise the molding end height in an elevation view. (I don't normally draw structural steel in an architectural system, but hopefully, there is a method. Any ideas on how I might do this? Link to comment Share on other sites More sharing options...
glennw Posted March 21, 2024 Share Posted March 21, 2024 Have you converted to a Molding Polyline or a 3D Molding Polyline? Link to comment Share on other sites More sharing options...
robdyck Posted March 21, 2024 Share Posted March 21, 2024 It needs to be a 3d molding. Then, you can simply raise the start or the end right in the molding dialog. Alternatively, the molding line can be adjusted in section view. Make sure the section camera is positioned parallel to the molding in plan view. Link to comment Share on other sites More sharing options...
RobWhite Posted March 27, 2024 Author Share Posted March 27, 2024 Thanks Fellas. It worked Link to comment Share on other sites More sharing options...
