StephenM Posted March 20, 2024 Share Posted March 20, 2024 I'm trying to get the dutch gable roof over the front porch, similar to the front of the garage but can't figure out why it won't work. I've attached pictures of what I'm trying to replicate as well as the file. T.I.A. for the help. Existing House.plan Link to comment Share on other sites More sharing options...
winterdd Posted March 20, 2024 Share Posted March 20, 2024 did you click on the porch railing, go to roof settings and click dutch gable? Link to comment Share on other sites More sharing options...
StephenM Posted March 20, 2024 Author Share Posted March 20, 2024 2 minutes ago, winterdd said: did you click on the porch railing, go to roof settings and click dutch gable? Yes, nothing happened for me when I did that. Link to comment Share on other sites More sharing options...
winterdd Posted March 20, 2024 Share Posted March 20, 2024 I couldn't get it to auto build without throwing things out of whack but just simply drew a roof plan over the front railing, made the eave heights the same and it came out great. I had to manipulate the roof connections and slide that gable wall back a tad to get it to look right. Link to comment Share on other sites More sharing options...
winterdd Posted March 20, 2024 Share Posted March 20, 2024 here is the saved file if you want it back...... 648273596_ExistingHouse.plan Link to comment Share on other sites More sharing options...
SNestor Posted March 21, 2024 Share Posted March 21, 2024 I gave it a shot...I did have to manually draw in the roof return. I placed notes on the roof plan view of this drawing; Here is the file; _ExistingHouse - fix plan.plan.zip Link to comment Share on other sites More sharing options...
StephenM Posted March 21, 2024 Author Share Posted March 21, 2024 Thanks for the help everyone! Good to know for future, that it is something you have to manually do. Link to comment Share on other sites More sharing options...
StephenM Posted March 21, 2024 Author Share Posted March 21, 2024 39 minutes ago, SNestor said: I gave it a shot...I did have to manually draw in the roof return. I placed notes on the roof plan view of this drawing; Here is the file; _ExistingHouse - fix plan.plan.zip Thank you for the roof notes. I did not catch that cricket. Link to comment Share on other sites More sharing options...
winterdd Posted March 21, 2024 Share Posted March 21, 2024 1 hour ago, StephenM said: Thanks for the help everyone! Good to know for future, that it is something you have to manually do. I am not sure how you set up the roof but when I do dutch gables they always auto build real nice for me. Link to comment Share on other sites More sharing options...
SNestor Posted March 21, 2024 Share Posted March 21, 2024 10 hours ago, winterdd said: I am not sure how you set up the roof but when I do dutch gables they always auto build real nice for me. I'm guessing...but, I think the issue with the "roof return" at the porch is that the return has to extend over the top of another roof. This might be what is causing this auto tool not to work properly. The auto roof needs a wall to attach to...and the railing wall which the roof return is assigned to stops at the garage...but the roof needs to continue past the garage wall. Link to comment Share on other sites More sharing options...
ericepv Posted March 21, 2024 Share Posted March 21, 2024 16 hours ago, StephenM said: I'm trying to get the dutch gable roof over the front porch, similar to the front of the garage but can't figure out why it won't work. I've attached pictures of what I'm trying to replicate as well as the file. T.I.A. for the help. Existing House.plan 9.88 MB · 9 downloads Check out this article from the Knowledge Base https://www.chiefarchitect.com/support/article/KB-00749/creating-a-dutch-hip-roof.html Link to comment Share on other sites More sharing options...
StephenM Posted March 22, 2024 Author Share Posted March 22, 2024 On 3/20/2024 at 6:30 PM, SNestor said: I gave it a shot...I did have to manually draw in the roof return. I placed notes on the roof plan view of this drawing; Here is the file; _ExistingHouse - fix plan.plan.zip I just noticed you used rafter when you did this. Can I continue with using rafters even though the renovation will be with trusses? Or what is the best way to transfer back to the use of trusses? Link to comment Share on other sites More sharing options...
