augusdo63 Posted March 14, 2024 Share Posted March 14, 2024 When I create a two story porch the windows on the second floor disappear. The shutters, if applicable, are still there, but the windows disappear. How can I fix this? Link to comment Share on other sites More sharing options...
SNestor Posted March 15, 2024 Share Posted March 15, 2024 check the 2nd floor wall and make sure it is properly aligned with the wall below. Or...better yet, post your plan so we can help you solve this issue. 1 Link to comment Share on other sites More sharing options...
parkwest Posted March 15, 2024 Share Posted March 15, 2024 What is a 2 story porch? Link to comment Share on other sites More sharing options...
augusdo63 Posted March 16, 2024 Author Share Posted March 16, 2024 9 hours ago, parkwest said: What is a 2 story porch? Did you see the pic I posted. It is a porch that is two stories tall. Link to comment Share on other sites More sharing options...
mthd97 Posted March 16, 2024 Share Posted March 16, 2024 Hi @augusdo63, Please post your plan so @SNestor can take a look at what is causing those windows to disappear above your entry. It looks like you have a void or a double height entry on the inside as well ? By just looking at your 3D view above, I would try looking at that entry wall and go into the structure panel of that wall and check the Ballooning radio button. Then try again to see if those windows remain. Then try a few more settings in the structure panel to see if it builds as you want. If that doesn’t work you may post your plan. Have fun troubleshooting ! Link to comment Share on other sites More sharing options...
SHCanada2 Posted March 16, 2024 Share Posted March 16, 2024 could also look at this one I had awhile ago Link to comment Share on other sites More sharing options...
