StephenM Posted March 13, 2024 Share Posted March 13, 2024 I'm trying to create a custom block window and I am not too sure how to go about achieving this. I've attached an image of exactly what I'm wanting to recreate for a window. Any helpful hints or being pointed to a forum that will help would be appreciated. Thanks, Link to comment Share on other sites More sharing options...
Rich_Winsor Posted March 14, 2024 Share Posted March 14, 2024 On 3/12/2024 at 5:37 PM, StephenM said: I've attached an image of exactly what I'm wanting to recreate for a window. Don't like to see legitimate inquiries go ignored. Had a play with this. There are a lot of things going on here. Basically I ended up stacking 3D Solid cubes (set to a glass material) to make the glass blocks. Converted cubes into an Architectural Block and set it into a hole in the wall. Used a 3D Molding Polyline around the opening for the Casing. Hopes this gives you somewhere to start. 1 1 Link to comment Share on other sites More sharing options...
StephenM Posted March 19, 2024 Author Share Posted March 19, 2024 Thanks for the help. Did you have to do anything to get the lines to show in the blocks to make it look like grout? Link to comment Share on other sites More sharing options...
Renerabbitt Posted March 19, 2024 Share Posted March 19, 2024 use fixed glass doors. you can mull them together and they will report to schedule: Link to comment Share on other sites More sharing options...
StephenM Posted March 19, 2024 Author Share Posted March 19, 2024 12 hours ago, Renerabbitt said: use fixed glass doors. you can mull them together and they will report to schedule: Did you create each block separately and then put them together to create a larger window? Link to comment Share on other sites More sharing options...
Renerabbitt Posted March 19, 2024 Share Posted March 19, 2024 9 minutes ago, StephenM said: Did you create each block separately and then put them together to create a larger window? yes each "block" is just a fixed door Link to comment Share on other sites More sharing options...
StephenM Posted March 20, 2024 Author Share Posted March 20, 2024 On 3/19/2024 at 2:43 PM, Renerabbitt said: yes each "block" is just a fixed door Hmm okay I did the fixed door for each block but it's only allowing me to have a max of 4" thickness. I've attached a photo what I got, but not sure how to make it full wall thickness? Link to comment Share on other sites More sharing options...
StephenM Posted March 25, 2024 Author Share Posted March 25, 2024 Looking on how I can adjust the thickness of this? I used a fixed door with glass slab but it's limiting it to a 4" thickness. Would like to have a 7" thickness. T.I.A for the help. Link to comment Share on other sites More sharing options...
rgardner Posted March 25, 2024 Share Posted March 25, 2024 1 hour ago, StephenM said: Looking on how I can adjust the thickness of this? I used a fixed door with glass slab but it's limiting it to a 4" thickness. Would like to have a 7" thickness. T.I.A for the help. Do they make a 7" thick glass block IRL? Link to comment Share on other sites More sharing options...
StephenM Posted March 25, 2024 Author Share Posted March 25, 2024 1 hour ago, rgardner said: Do they make a 7" thick glass block IRL? I guess what I'm really trying to do here is get rid of the ledge part. As I want this to be flush on the exterior. Link to comment Share on other sites More sharing options...
rgardner Posted March 25, 2024 Share Posted March 25, 2024 1 hour ago, StephenM said: I guess what I'm really trying to do here is get rid of the ledge part. As I want this to be flush on the exterior. change the swing of the door to exterior swing and will be flush with exterior. Link to comment Share on other sites More sharing options...
