AAInteriors Posted February 29, 2024 Share Posted February 29, 2024 I can't seem to figure out how to get my balconies to attach to the correct area (floor is 24"). Any advice would be greatly appreciated! Link to comment Share on other sites More sharing options...
Gawdzira Posted March 1, 2024 Share Posted March 1, 2024 A balcony is a room. You can select that room and adjust it's floor height to where you want it. Probably an inch or 2 below the respective floor level Link to comment Share on other sites More sharing options...
Michael_Gia Posted March 1, 2024 Share Posted March 1, 2024 16 hours ago, AAInteriors said: I can't seem to figure out how to get my balconies to attach to the correct area (floor is 24"). Any advice would be greatly appreciated! I'm suspecting that you are copying balcony railings from one floor to another. That's a recipe for disaster in my experience. It can be done but you often have to go back and select the exterior balcony room and reset it's floor elevation, like Alan said before. Link to comment Share on other sites More sharing options...
AAInteriors Posted March 2, 2024 Author Share Posted March 2, 2024 I still can't seem to figure it out....are there any videos out there? The balconies are not attaching in the correct place. Link to comment Share on other sites More sharing options...
AAInteriors Posted March 2, 2024 Author Share Posted March 2, 2024 WOuld you be willing to send a screen shot of where to "reset" the floor elevation? Link to comment Share on other sites More sharing options...
SNestor Posted March 2, 2024 Share Posted March 2, 2024 The balcony is a "room". If you click in the balcony...then, open it using the door icon on the bottom edit toolbar...in this dialogue, open the structure tab. This is where you can set the elevation for the room. You could also go to "EDIT>RESET TO DEFAULT...select "all floors"....and select "floor heights". You may need to select "ceiling heights" also. This will reset your rooms to the "default" heights...which are specified in "DEFAULTS" (the wrench icon on the top toolbar)...then go to "FLOORS AND ROOMS>FLOOR LEVELS. This is where your default floor/ceiling heights are stored. Link to comment Share on other sites More sharing options...
