decorators3 Posted February 25, 2024 Share Posted February 25, 2024 Hi Attached is the back exterior view (m walk out Basement) however the garage to left has no basement , does this terrain and slope make any sense. I need to also install steps in sloped back too one I figure out how to do it But right now I'm wondering of this looks ok ( yes there are a few things to clean up on the back walls) Levina Link to comment Share on other sites More sharing options...
Gawdzira Posted February 25, 2024 Share Posted February 25, 2024 This diagram is for an article regarding deck guardrails but the same concept should apply to retaining walls. If you have more than a 30" grade drop at 30" away from your retaining wall, consider the use of a guardrail to protect from falls. Link to comment Share on other sites More sharing options...
DBCooper Posted February 25, 2024 Share Posted February 25, 2024 That drop off looks to be a little steep without a retaining wall. Your siding probably shouldn't be going all the way down to the dirt. Should probably have a patio/slab outside of the sliding and french doors. Link to comment Share on other sites More sharing options...
decorators3 Posted February 26, 2024 Author Share Posted February 26, 2024 thanks for all your input Levina Link to comment Share on other sites More sharing options...
