65Shelby Posted February 23 Share Posted February 23 (CA x13) Hey guys, I havent been on here in a while and just been working on a house plan that we would like to build. Found a house, love the layout but cant figure out how to draw the upstairs with the big sloped roof as you see... Here is the actual house and then my attempt.... (Very rough, so no laughing) Not sure how to build out those gable-ended loft areas. (3 in total) Link to comment Share on other sites More sharing options...
ericepv Posted February 23 Share Posted February 23 You can start by letting Auto Roof draw it for you and the modify as needed. You can also select the walls for the garage and your front porch and mark them as 'Full Gable Wall' (in the roof tab of the DBX) or use the gable wall tool on the lower toolbar. Take a look at this article https://www.chiefarchitect.com/support/article/KB-00758/generating-automatic-hip-and-gable-roofs.html Link to comment Share on other sites More sharing options...
65Shelby Posted February 23 Author Share Posted February 23 24 minutes ago, ericepv said: You can start by letting Auto Roof draw it for you and the modify as needed. You can also select the walls for the garage and your front porch and mark them as 'Full Gable Wall' (in the roof tab of the DBX) or use the gable wall tool on the lower toolbar. Take a look at this article https://www.chiefarchitect.com/support/article/KB-00758/generating-automatic-hip-and-gable-roofs.html Thanks Eric- Im trying that but the way each room upstairs is setup, its like a loft so Im missing something These red lines, show the actual room size (approximate). I will look at your link and see if that helps. Link to comment Share on other sites More sharing options...
ericepv Posted February 23 Share Posted February 23 You'll have to create a second floor if you want conditioned rooms in that space. Select 'Make new blank plan for the 2nd floor' then draw in the walls manually. Link to comment Share on other sites More sharing options...
MoeGia Posted February 25 Share Posted February 25 Create a second floor. Set the default ceiling height at 1.5". create rooms over the garage and for the large dormer to 24" or whatever height you think the knee walls are. Mark your gables and let auto-roofs do it's thing. Tinker with the heights until you get what close to what you want. You'll have to do some manual editing. Turn off auto-roofs and adjust. Set the default ceiling height to full ceiling height. The front dormer roof eaves will have to be manually pulled down. . Link to comment Share on other sites More sharing options...
