DHerb2014 Posted February 19, 2024 Share Posted February 19, 2024 Question - is there a way we can modify the Door and Window Schedules to display the sizes in inches rather than current format? Please see attachment for configuration options? DOOR SCHEDULE PDF.pdf Link to comment Share on other sites More sharing options...
rlackore Posted February 19, 2024 Share Posted February 19, 2024 I don't think so - maybe a macro can be used, there are smarter people that may provide a more definitive answer. I use Width and Height columns (which can be formatted for whatever number type you want) instead of a Size column: 1 Link to comment Share on other sites More sharing options...
robdyck Posted February 19, 2024 Share Posted February 19, 2024 The simplest way would be to use the Label column in the schedule and have your window labels display the width x height in inches. Copy this into the window label field: %width% x %height% Link to comment Share on other sites More sharing options...
DHerb2014 Posted February 19, 2024 Author Share Posted February 19, 2024 Robert(s), thanks for your comments. Both work the same way and get identical results. Is there a way to manipulate one or more of the doors in the schedule to just show feet in lieu of inches? E.g., a very large, wide garage door 22' wide x 8' high. Can someone manipulate it this way? If not, it would display 264" x 96". Link to comment Share on other sites More sharing options...
rlackore Posted February 19, 2024 Share Posted February 19, 2024 I'm certain that you can use R. Dyck's solution with a custom macro. I'm not smart enough to provide a macro. Link to comment Share on other sites More sharing options...
robdyck Posted February 20, 2024 Share Posted February 20, 2024 21 hours ago, DHerb2014 said: E.g., a very large, wide garage door 22' wide x 8' high. Can someone manipulate it this way? If not, it would display 264" x 96". The simplest way for large doors that are sized in 1foot increments is to use %width/12%' Notice I've added the ' designator and you'll need to uncheck Use Default Formatting to get rid of the " designator. I don't know anything about macros but I'll offer what I do know. You can make a copy of Chief's macro "FormattedWidthNearestInch" and rename it "FormattedWidthNearestFoot" Then edit the macro: obj = owner obj = referenced unless referenced.nil? obj.width.to_ft.round Link to comment Share on other sites More sharing options...
robdyck Posted February 20, 2024 Share Posted February 20, 2024 Another Option: Copy this macro and rename, then edit the obvious parameters "FormattedWidthSixteenths". Place the new macro in the door label. Link to comment Share on other sites More sharing options...
robdyck Posted February 20, 2024 Share Posted February 20, 2024 I'm sure those who know macros can offer much better solutions but until then... Link to comment Share on other sites More sharing options...
Renerabbitt Posted February 20, 2024 Share Posted February 20, 2024 3 hours ago, robdyck said: I'm sure those who know macros can offer much better solutions but until then... you probably wanna use '/" Link to comment Share on other sites More sharing options...
DHerb2014 Posted February 20, 2024 Author Share Posted February 20, 2024 Rene, Please explain where "I" is located? No idea. Thanks Link to comment Share on other sites More sharing options...
Renerabbitt Posted February 20, 2024 Share Posted February 20, 2024 # Copyright Rabbitt Design 2024 # Initializing the NumberFormatter to format width in fractional inches number_formatter = NumberFormatter.new number_formatter.unit = '"' # Set the unit to inches number_formatter.use_fractions = true # Enable fraction display number_formatter.denominator = 16 # Set precision to 1/16th of an inch number_formatter.show_unit = true # Ensure the unit ("in") is not automatically included # Assuming 'width' is a publisher variable representing the width measurement # Apply the number formatter directly to the width measurement and append the inch symbol number_formatter.apply(width) there is a code for you, set to eval and object base. FYI my Pro Plan has a very complex and dynamic label for windows and doors for anyone catching this and is interested. It dynamically changes its formatting based on the layer set or size of the window, new vs existing, as well as user configurable options. Window schedule is pretty advanced too Link to comment Share on other sites More sharing options...
