cbucks Posted February 19, 2024 Share Posted February 19, 2024 I can calc manually but there are small areas and curious if there is a way to sum up the total amount of grass and display as an automatic calculation? Link to comment Share on other sites More sharing options...
MarkMc Posted February 19, 2024 Share Posted February 19, 2024 Well you can add polylines around each grass area, set to include in a custom schedule and get a total. BUT that is a lot of work. I've more often had to include impermeable area which is already (hopefully) made up of polyline objects. Make a schedule for all the impermeable. Then separately subtract that total from the lot total. Link to comment Share on other sites More sharing options...
rgardner Posted February 19, 2024 Share Posted February 19, 2024 1 hour ago, cbucks said: I can calc manually but there are small areas and curious if there is a way to sum up the total amount of grass and display as an automatic calculation? Maybe check out @Renerabbitt's pro template. Has all of this already built in with macros and FAR/Area caculations schedules. Link to comment Share on other sites More sharing options...
