dougbbuilders Posted January 31, 2024 Share Posted January 31, 2024 Good Morning, I have an issue with 3D. I have read a few threads, but I can't figure what I have check on in the past week that is causing seriously slow movement just in the 3D camera view. I have several plans that are slow, so I don't believe that it is the plan, vs maybe RTRT. I am unsure what I can turn off to improve my lag Link to comment Share on other sites More sharing options...
Designers_Ink Posted January 31, 2024 Share Posted January 31, 2024 When you pull up a camera view, look at the bottom of the screen, and it should tell you how many surfaces you have in the model (i.e. Done: 146857 surfaces). If the number goes away, just rotate the camera view, and it will come back up. I'd be interested to see if you have a high number of surfaces in your model, which could slow things down. You can always do a "Backup Entire Plan" to a zip file and post it. That way we can pull up your model with your materials and see if it is model related or maybe a computer related issue if it opens fine in our systems. Link to comment Share on other sites More sharing options...
DBCooper Posted January 31, 2024 Share Posted January 31, 2024 There are some good tips in this tech article: https://www.chiefarchitect.com/support/article/KB-00521/troubleshooting-slowness-in-chief-architect-plans.html#3DSlowness Link to comment Share on other sites More sharing options...
dougbbuilders Posted January 31, 2024 Author Share Posted January 31, 2024 Here it is, just started it yesterday, so I is still a pretty small file Nelson Plan.zip Link to comment Share on other sites More sharing options...
DBCooper Posted January 31, 2024 Share Posted January 31, 2024 Seems fine to me in X15. Might be a system or video card problem on your machine. Link to comment Share on other sites More sharing options...
Designers_Ink Posted January 31, 2024 Share Posted January 31, 2024 Same here. Are you using a laptop or desktop? What kind of video card are you running? Link to comment Share on other sites More sharing options...
dougbbuilders Posted January 31, 2024 Author Share Posted January 31, 2024 I am using a desktop, and have for a year. Just recently started moving really slow. Last few projects I have a Intel(R)Iris(R)Xe Graphics NVIDIA Geforce MX 550 Link to comment Share on other sites More sharing options...
dougbbuilders Posted January 31, 2024 Author Share Posted January 31, 2024 Thanks for help with my issue. Is there any adjustments I can make in the 3d settings that will help speed things up? Link to comment Share on other sites More sharing options...
Kbird1 Posted February 1, 2024 Share Posted February 1, 2024 9 hours ago, dougbbuilders said: so I don't believe that it is the plan, vs maybe RTRT. You aren't doing RTRT with an MX550 , it's not capable as it doesn't have the RTX hardware built in, ( see Prefs. > Render > Video Card Status ) and my guess is you no longer have sufficient (shared) Video Memory either so Chief is defaulting to X12's default PBR view , might be time to finally get yourself a new computer assuming you are using X15? If you are using Chief Premier X15 you might want to do your Forum Signature and include your Version of Chief and Hardware etc so you don't need to supply that Info every time.... Mick. Link to comment Share on other sites More sharing options...
