HumbleChief Posted January 26 Share Posted January 26 Is there a way to auto frame this condition? Instead of rafters butting into the ridge? Link to comment Share on other sites More sharing options...
para-CAD Posted January 27 Share Posted January 27 I don't think there is a drop structural ridge for auto framing. I've always done complex CAD framing mostly manually. This is a Lindal Cedar home I once framed a while ago. Auto Dropped Ridge would be handy when drawing this. 1 Link to comment Share on other sites More sharing options...
GeneDavis Posted January 27 Share Posted January 27 You might try a 1/16" square ridge and edit it's material to air gap, then manually add the structural one. 1 1 Link to comment Share on other sites More sharing options...
para-CAD Posted January 28 Share Posted January 28 I would have NEVER for the life of me come up with the idea to make a micro ridge. Wow. You are probably good at complex puzzles. That is a helluva work around suggestion. When I get stuck like this, my default is 3D polyline solid...I know, the cheater way. Lately I've been creating accurate 3D framing drawings with sketchup. But then I am importing a .jpg, .png, or .pdf so that's a pain when something gets changed. 1 Link to comment Share on other sites More sharing options...
HumbleChief Posted January 29 Author Share Posted January 29 Thanks very much! Did it manually but only because I never thought of your great suggestion Gene!! Link to comment Share on other sites More sharing options...
GeneDavis Posted January 30 Share Posted January 30 My suggestion upthread is hereby amended. I'd forgotten that you can simply uncheck "ridge" in the framing dialog for roof planes, and that when you draw the ridge as a roof beam after framing the rafters it is properly located under them. If you want a beveled top on that beam, sawn and not a seat piece stacked, and you want to see it in 3D, you'll do the beam as a solid. Or you can jack it up with a move, and annotate with a detail that the top end of the rafters all get a small birdsmouth. 1 Link to comment Share on other sites More sharing options...
