Stack Rafters 'Over' Ridge Beam?
HumbleChief
I would have NEVER for the life of me come up with the idea to make a micro ridge.  Wow.  You are probably good at complex puzzles.  That is a helluva work around suggestion.
When I get stuck like this, my default is 3D polyline solid...I know, the cheater way.
Lately I've been creating accurate 3D framing drawings with sketchup.  But then I am importing a .jpg, .png, or .pdf so that's a pain when something gets changed.
My suggestion upthread is hereby amended.  I'd forgotten that you can simply uncheck "ridge" in the framing dialog for roof planes, and that when you draw the ridge as a roof beam after framing the rafters it is properly located under them.  If you want a beveled top on that beam, sawn and not a seat piece stacked, and you want to see it in 3D, you'll do the beam as a solid.  Or you can jack it up with a move, and annotate with a detail that the top end of the rafters all get a small birdsmouth.
