DRyeHD Posted January 25, 2024 Share Posted January 25, 2024 A customer wants a custom stove exhaust cover. I'm close by using a cabinet with peninsula radius. The problem is that i need a smaller radius on the corners (probably 6-12") to allow enough room for the actual exhaust fan. I can't find a way to decrease the radius. Is there another method that would be better to create this in CA? Link to comment Share on other sites More sharing options...
robdyck Posted January 25, 2024 Share Posted January 25, 2024 I probably would have used a 3d solid for that. Easy to re-size and you could do a polyline subtraction to make a hole in the bottom for a range hood insert. I'd find it quicker than using cabinet tools. Link to comment Share on other sites More sharing options...
MarkMc Posted January 25, 2024 Share Posted January 25, 2024 For that just a molding line. I started with a pline box so you can change radius there before converting also easier to make a top to go with it if you need one. Link to comment Share on other sites More sharing options...
DRyeHD Posted January 25, 2024 Author Share Posted January 25, 2024 @robdyck and @MarkMc thanks for the ideas. I'm going to try both! Link to comment Share on other sites More sharing options...
