RobWhite Posted January 23, 2024 Share Posted January 23, 2024 I am creating a large curve portal beam. 27000mm radius. How to I increase the curve segments? The default has too long segments in the curve, which does not look curved. The view of the I beam should be a nice, curved bend rather than an octagonal... hexagonal etc stagger look. Link to comment Share on other sites More sharing options...
glennw Posted January 23, 2024 Share Posted January 23, 2024 I assume you use a 3D Solid and curved it. Select the Solid by the curved edge. On the Edit menu select Convert Curve To Polyline. You can then specify the number of segments. Link to comment Share on other sites More sharing options...
DBCooper Posted January 23, 2024 Share Posted January 23, 2024 The other thing that can work is if you select the arc and open the dialog you might get the "selected arc" panel. You can then uncheck "auto facet angle" and change it to a smaller value, something like 1 degrees instead of 7.5. Link to comment Share on other sites More sharing options...
