winterdd Posted January 17, 2024 Share Posted January 17, 2024 What do you guys who manually record videos have your settings at? I can record slowly while doing a bird's eye view over the home with the roof removed but at playback it has a very high speed rate. Tired of telling my client to pause the video and slide the play bar to slow it down. This is happening since I started X15 earlier this month. Obviously I am doing something wrong. Thanks..... Link to comment Share on other sites More sharing options...
VHampton Posted January 17, 2024 Share Posted January 17, 2024 Frames per second controls the speed. If the 15 is reduced to 7, it's much better, but still on the fast side. Thanks for posting, I'd like to learn more about this as well. 1 Link to comment Share on other sites More sharing options...
winterdd Posted January 17, 2024 Author Share Posted January 17, 2024 2 minutes ago, VHampton said: Frames per second controls the speed. If the 15 is reduced to 7, it's much better, but still on the fast side. Thanks for posting, I'd like to learn more about this as well. Awesome thanks, the whole compression thing I have always guessed at. On the exterior walk around I do a walkway path and it records great and very professional looking. When it comes to manually recording I need improvements haha. Link to comment Share on other sites More sharing options...
ProPlan_2011 Posted January 17, 2024 Share Posted January 17, 2024 Walkthrough paths give you more control, specifically speed. Link to comment Share on other sites More sharing options...
winterdd Posted January 17, 2024 Author Share Posted January 17, 2024 36 minutes ago, ProPlan_2011 said: Walkthrough paths give you more control, specifically speed. Walk thru paths inside the home gets difficult. I assume the guys who do it do not record one video but combine many into one (ie. editing) That is something I haven't ever got into. Link to comment Share on other sites More sharing options...
ProPlan_2011 Posted January 17, 2024 Share Posted January 17, 2024 1 hour ago, winterdd said: Walk thru paths inside the home gets difficult. I assume the guys who do it do not record one video but combine many into one (ie. editing) That is something I haven't ever got into. I do inside walkthroughs often. Not sure what particular aspect you find difficult. My walkthroughs are one video with multiple key frames. I've even done two story walkthroughs in one video. Share your pain, I'm sure many can help. Link to comment Share on other sites More sharing options...
winterdd Posted January 17, 2024 Author Share Posted January 17, 2024 1 hour ago, ProPlan_2011 said: My walkthroughs are one video with multiple key frames. This is probably what I need to look into learning. Link to comment Share on other sites More sharing options...
DBCooper Posted January 18, 2024 Share Posted January 18, 2024 Try this video: https://www.chiefarchitect.com/videos/watch/10208/3d-walkthroughs-how-to-make-great-virtual-tours.html Link to comment Share on other sites More sharing options...
