KnotSquare Posted December 29, 2023 Share Posted December 29, 2023 MTW Deck Brackets (540) 334-4294 www.metwood.com 3,250 bls per bracket For dimensions and structural information: https://www.metwood.com/wp-content/uploads/2023/01/SDDocument_CCRR0261.pdf General Flyer: https://www.metwood.com/wp-content/uploads/2023/01/DECK-BRACKET-FLYER.pdf MTW Deck Bracket.calibz Link to comment Share on other sites More sharing options...
jtcapa1 Posted January 2, 2024 Share Posted January 2, 2024 I like this bracket idea. You might elaborate on why these are becoming more necessary today. I've struggling with a newel post edge detail, where I've got an AWS concrete deck pavers system which I'd like to drain over the edge, while creating a nice looking trim detail. I spend way too much time trying to figure out how it would be done. The original designer drew up a nice clean system, but how the F**K you'd build it was not considered. Link to comment Share on other sites More sharing options...
Greg_NY61 Posted January 3, 2024 Share Posted January 3, 2024 There is a much easier method to install a ledger on top of the existing brick veneer surface using Simpson BVLZ brick ledger connector. I can see MTV bracket being used in new construction prior to brick installation so it can be properly flashed, etc. and extra blocking can be installed along the rim joist... In existing construction it would be a pain in the a$$ to use this bracket especially if there is existing finished basement. @John JT, You need a fascia mount bracket, they make both for flush mount and and flush mount with offset... The one with offset mounts to fascia when decking or flashing extend beyond the fascia board, post mounts 1-1/4" from fascia. Good luck and happy New Year. Link to comment Share on other sites More sharing options...
Gawdzira Posted January 3, 2024 Share Posted January 3, 2024 The paver stand off system I used on my last project had an additional bracket for the end of the run to hold a rip of the stone vertical. I will search this detail up. Link to comment Share on other sites More sharing options...
Gawdzira Posted January 3, 2024 Share Posted January 3, 2024 Vertical closure clips. https://mrpsupports.com/products/product:vertical-closure-clips/ I did not use them on this project since I did not want to see the small tabs over the stone. I did this one with some Boral boards painted and then screwed to the posts which allow for a small gap for drainage. Link to comment Share on other sites More sharing options...
KnotSquare Posted January 4, 2024 Author Share Posted January 4, 2024 I use these brackets where my projects require that I extend a ledger board out beyond continuous insulation. They can come with or stuffed with insulation in the void minimizing the thermal bridging affect. They provide a good distance of stand off for my typical installations of (20 1.5" layers of mineral wool. Link to comment Share on other sites More sharing options...
GaryOhmer Posted January 4, 2024 Share Posted January 4, 2024 We use the Maine deck bracket here in se alaska with up to 16' of rain. ESR-1331-Maine-Deck-Bracket.pdf 1 Link to comment Share on other sites More sharing options...
