Remove balustrade around top of stairwell
gelbuilding
Define the railing as invisible - you will need some sort of wall/railing to maintain the opening.
Or...the better way:
Define the railing so that it builds like your detail with only the vertical timbers (balusters).
Easy to add a top and/or bottom plate (rail) if needed.
1646104786_Screenshot2023-12-21at11_14_35pm.thumb.jpg.6f63267ae9a920aea460ead38baaeb9e.jpg
You need to move the wall/railing that defines the floor opening for the stairs.
A room polyline doest have anything to do with the floor opening unless you convert it to a Hole In Floor Platform.
You could also use Build>Floor>Hole In Floor Platform to define a floor hole if you dont want to use walls/railings.
