wpdesigninc Posted December 12, 2023 Share Posted December 12, 2023 I aimed to use a simple soffit detail to shower a sloped shower floor base for drainage to a linear drain. However, I need the slope to run side to side not back to front. From what I can tell, the soffit detail only lets you specify drop front to back. How would you build this detail into your plan to show the angle in plan view so it renders properly and details in a wall elevation as well. I need to also show the 3/8" tile on top of this. in an elevation view. Using X15. Thanks! Link to comment Share on other sites More sharing options...
rgardner Posted December 12, 2023 Share Posted December 12, 2023 2 hours ago, wpdesigninc said: I aimed to use a simple soffit detail to shower a sloped shower floor base for drainage to a linear drain. However, I need the slope to run side to side not back to front. From what I can tell, the soffit detail only lets you specify drop front to back. How would you build this detail into your plan to show the angle in plan view so it renders properly and details in a wall elevation as well. I need to also show the 3/8" tile on top of this. in an elevation view. Using X15. Thanks! Lots of ways to do this but if you want to stay with the soffit turn the soffit 90 degrees. Link to comment Share on other sites More sharing options...
wpdesigninc Posted December 12, 2023 Author Share Posted December 12, 2023 I tried that - and resized it - and it displayed in the same format Link to comment Share on other sites More sharing options...
RobDesLLC Posted December 14, 2023 Share Posted December 14, 2023 Make a sloped polyline in elevation view, then convert to a 3D solid, change material to your floor tile, and adjust the depth in plan view so it snaps to each wall. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted December 14, 2023 Share Posted December 14, 2023 I'd use a Ramp. Link to comment Share on other sites More sharing options...
para-CAD Posted December 15, 2023 Share Posted December 15, 2023 I hope this is received well. This chief site works best as a repository of good, searchable content when Questions and asking "how to" is located in the Q & A section. Typically, people come to the Tips & Techniques section to learn some cool new way to accomplish something new that someone has discovered and is now sharing, not to ask How To but the share How To. 2 Link to comment Share on other sites More sharing options...
