JKEdmo Posted December 6, 2023 Share Posted December 6, 2023 I feel like I should know this by now, but I don't. What's the difference between space bar and escape keys in Chief, if any? I find myself wanting to use the escape key a lot to "leave" a tool mode. Likely a habit from other programs... Thanks again, Jim Link to comment Share on other sites More sharing options...
Solution DBCooper Posted December 6, 2023 Solution Share Posted December 6, 2023 "Space" always puts you into select objects (arrow) mode. "Escape" will either cancel the current selection or put you back into the previous command mode. Also, if you go into the customize hotkeys dialog and type in either, it will give you a general description of each. 1 Link to comment Share on other sites More sharing options...
kellyh Posted December 6, 2023 Share Posted December 6, 2023 @DBCooperhit the nail on the head. Spacebar is the default hotkey for "Select Objects" mode. The escape key will close an open dialog or cancel out of an open text box (think moving objects with dimensions). If you don't have a dialog open or a text box active, the escape key will then cycle in reverse order through the tools you previously used. So, pretend you had drawn some walls, then placed a window, then placed a base cabinet. If you then pressed the escape key, you would change from the base cabinet tool back to the window tool. If you pressed escape again, you would then go back to the wall tool. 1 Link to comment Share on other sites More sharing options...
JKEdmo Posted December 6, 2023 Author Share Posted December 6, 2023 15 minutes ago, DBCooper said: "Space" always puts you into select objects (arrow) mode. "Escape" will either cancel the current selection or put you back into the previous command mode. Also, if you go into the customize hotkeys dialog and type in either, it will give you a general description of each. Thanks! Very helpful. Jim Link to comment Share on other sites More sharing options...
JKEdmo Posted December 6, 2023 Author Share Posted December 6, 2023 5 minutes ago, kellyh said: @DBCooperhit the nail on the head. Spacebar is the default hotkey for "Select Objects" mode. The escape key will close an open dialog or cancel out of an open text box (think moving objects with dimensions). If you don't have a dialog open or a text box active, the escape key will then cycle in reverse order through the tools you previously used. So, pretend you had drawn some walls, then placed a window, then placed a base cabinet. If you then pressed the escape key, you would change from the base cabinet tool back to the window tool. If you pressed escape again, you would then go back to the wall tool. Thanks. Super helpful. I watched how escape cycles through different tools, and thought it was tripping out! Jim Link to comment Share on other sites More sharing options...
Butchmds Posted February 15 Share Posted February 15 This sounds like BS. All the software I use the escape key kills the current command. I find this a very annoying feature that the Esc Key does not function in this manner. I have been using CAD software for 35 years and I have found the Esc key always kills the current command. I have been using Chief Arch for about 2 months and it really is an issue when I want to stop dimensioning and hit escape only to find I'm still in the command and the space bar is the only manner in which to kill the command. Butchmds. 1 Link to comment Share on other sites More sharing options...
glennw Posted February 15 Share Posted February 15 What tool do you want to be in when you have "killed the current command"? Link to comment Share on other sites More sharing options...
