Sketchup or 3Ds Model conversion to CA plan file?
jtcapa1
I'm wondering if there is a way to save some time and open or import a complete 3d model made in sketchup into CA that is NOT a symbol?
I've imported both a 3ds file and .skp file, but there is not much I can do with them.
I want to create a typical CA plan file and CA 3d model.
No, 3D imports will always be a symbol. You have to draw in Chief.
Depending on version of SU, could export a 2D dwg  (or pdf floor plans) of each floor then trace in CA. You will be able to snap to lines of a dwg but not a pdf.
Damn.  Thanks guys.  I was hoping I was just missing something.
What about getting another kind of exported format from the out of country Architect?
I did get the Autocad plans in a weird metric scale that came in 3,000% to large on the first try.
So I can at least draft over it.
It would be sooo nice if AutoCad had an export to *.plan file in their quiver.
