jtcapa1 Posted November 21, 2023 Share Posted November 21, 2023 I'm wondering if there is a way to save some time and open or import a complete 3d model made in sketchup into CA that is NOT a symbol? I've imported both a 3ds file and .skp file, but there is not much I can do with them. I want to create a typical CA plan file and CA 3d model. Link to comment Share on other sites More sharing options...
MarkMc Posted November 21, 2023 Share Posted November 21, 2023 11 minutes ago, jtcapa1 said: I'm wondering if there is a way to save some time and open or import a complete 3d model made in sketchup into CA that is NOT a symbol? No, 3D imports will always be a symbol. You have to draw in Chief. Depending on version of SU, could export a 2D dwg (or pdf floor plans) of each floor then trace in CA. You will be able to snap to lines of a dwg but not a pdf. Link to comment Share on other sites More sharing options...
GeneDavis Posted November 21, 2023 Share Posted November 21, 2023 Cannot be done. I can think of ways a SU model can be worked so it can provide a 2D plan in Chief CAD so the walls can all be traced, but that really only gets you started with a plan. Link to comment Share on other sites More sharing options...
jtcapa1 Posted November 21, 2023 Author Share Posted November 21, 2023 Damn. Thanks guys. I was hoping I was just missing something. What about getting another kind of exported format from the out of country Architect? I did get the Autocad plans in a weird metric scale that came in 3,000% to large on the first try. So I can at least draft over it. It would be sooo nice if AutoCad had an export to *.plan file in their quiver. Link to comment Share on other sites More sharing options...
GeneDavis Posted November 21, 2023 Share Posted November 21, 2023 Just do the work. In the time you've spent posting here, you could have the mass all modeled in Chief. 1 Link to comment Share on other sites More sharing options...
