Diamond Shaped Window
CCarpenter
How can I make a diamond shaped window - essentially a square window turned 90 degrees? There is no turn handle on windows. In the Transform/Replicate tool Rotate is grayed out when in a window. If I open it and go to shape or arch there is no arch that is applicable and in shape there's no way to rotate it either. I can't find a diamond window in Andersen or Marvin or in the Chief Architect Library. I know there has got to be a way and I'm sure it is simple and staring me in the face.
Thanks for your help.
CA Premier X15
Try a tudor arch, set the height of the arch to 1/2 the window height, don't specify a radius, and then check the box for reflect vertically.
Pretty simple but not at all obvious and it sure would be nice if you could just rotate a normal window.
  • 4 months later...
