DH7777 Posted October 21, 2023 Share Posted October 21, 2023 I see in the door dialog box you can check a box for plinth blocks but it does nothing. I read another comment that said in CA you have to manually place them at each door. So what is the point in have the box to check if it does nothing and why did the CA software creators not think to allow for this. This should have been a basic application in the first CA program. I'm using x11... am I missing something here? Link to comment Share on other sites More sharing options...
robdyck Posted October 21, 2023 Share Posted October 21, 2023 Plinth blocks are an item that don't generate a 3d component. Plinth blocks do not display in 3D views, but are counted in the Materials List. 1 Link to comment Share on other sites More sharing options...
Kbird1 Posted October 21, 2023 Share Posted October 21, 2023 Rob is correct, it has always been this way. If you really need them in 3D, it is not too hard to make a Symbol from some solids, so you don't need to place them individually. Mick. 1 Link to comment Share on other sites More sharing options...
