Problems to lock in place small corners
Quatermain
Hello,
i do have some problems with small corners 400mm by 400mm,
When I have them right, and i want to change something else on the other side of the wall, the corner will be automatic delete.
Even locking walls does not make a differents.
changing wall connecties does also not fix the problem.
try with different layout of walls, i notices only that the problem is more when the thickness of the wall is bigger.
The problem is in any versions of chief architect.
Is there anyway to fix this?
4 hours ago, Quatermain said:
Even locking walls does not make a different.
Just a note that Locking Walls in chief is not possible, all you are really doing with the Lock button ( in the ALDO/Display Options) is stopping the ability to select them in that view.
Short Walls like this have always been a bit of a hassle in Chief unfortunately....
Hello,
Try a grid of room dividers to allow the walls to snap to them.
