Ed_Orum Posted October 12, 2023 Share Posted October 12, 2023 I have a wall in a building that is at 37 degrees. I drew a rectangular box (20' x 3") and need to rotate to box to the 37 degrees. But when I click on the box, the best I can do is rotate the selected line. I want to rotate the entire box, all at the same time. I drew a selection box around the rectangle, as opposed to clicking on it, and there is no option to rotate the box. So, I have to be missing something, as rotating a rectangle is one of the most basic 2D drawing operations that exist. Thanks in advance. Lane Link to comment Share on other sites More sharing options...
Chopsaw Posted October 12, 2023 Share Posted October 12, 2023 Sounds a lot like you are using the "Make Parallel/Perpendicular" tool. If so double click the tool for the option to "Rotate entire polyline" 1 Link to comment Share on other sites More sharing options...
tundra_dweller Posted October 12, 2023 Share Posted October 12, 2023 What Chopsaw said, or use the transform/replicate tool if you're not making it parallel to another object... Link to comment Share on other sites More sharing options...
Ed_Orum Posted October 12, 2023 Author Share Posted October 12, 2023 I did not know about the double click. Thanks so much! Link to comment Share on other sites More sharing options...
CharlesVolz Posted October 12, 2023 Share Posted October 12, 2023 On 10/12/2023 at 4:52 PM, Ed_Orum said: I did not know about the double click. Thanks so much! Expand or Alt-click Link to comment Share on other sites More sharing options...
