RobWhite Posted September 20, 2023 Share Posted September 20, 2023 How do raise the eave soffit. As per the image below the soffit lining is hanging about 50mm below the barge. Link to comment Share on other sites More sharing options...
Gawdzira Posted September 20, 2023 Share Posted September 20, 2023 Reduce the size of your eave fascia. The soffit is set to follow that. Link to comment Share on other sites More sharing options...
Chopsaw Posted September 20, 2023 Share Posted September 20, 2023 On 9/20/2023 at 1:29 AM, Gawdzira said: Reduce the size of your eave sub fascia. The soffit is set to follow that. Expand The soffit actually should follow the Sub Fascia but it seems there is something wrong as your settings should be working. Did you change something without reframing ? Link to comment Share on other sites More sharing options...
Gawdzira Posted September 20, 2023 Share Posted September 20, 2023 Oops, I thought it but I did not type it. Link to comment Share on other sites More sharing options...
