basilbabaa Posted September 9, 2023 Share Posted September 9, 2023 Apparently I do not understand how to set default material settings. In this video, I'm experiencing some difficulties while working in X15. I'm trying to change the default exterior wall materials, but whenever I select the walls and choose the default material, it keeps reverting back to a blue siding instead of the one I have set. I'll show you the steps I've taken and the issue I'm facing. If you have any suggestions or solutions, please let me know in the comments. https://www.loom.com/share/16e4302e0e224bbf965a2947ff233d58?sid=131c2a53-7151-4065-a654-75f5f459f72b Thanks. Link to comment Share on other sites More sharing options...
SHCanada2 Posted September 9, 2023 Share Posted September 9, 2023 what is the exterior material for the wall type? If you change that it will change the material Link to comment Share on other sites More sharing options...
Kbird1 Posted September 10, 2023 Share Posted September 10, 2023 The Blue is Chief's default material for the default Ext. WALL TYPE , something is messed up, haven't been using the Paint Can Tool have you? Open the WallType in the Defaults > Exterior Wall > Wall Type Tab and check what's there... this is the Best way to change an entire Plan's Wall's , however it will only change walls that are still considered "Default Walls" , so if you have pull the top or bottom or spraycan a new color etc you need to fixed those manually, this thread may help with that........... https://chieftalk.chiefarchitect.com/topic/31850-paint-can-tool-material-painter-best-practices/?tab=comments#comment-250698 M. Link to comment Share on other sites More sharing options...
