JKEdmo Posted September 8, 2023 Share Posted September 8, 2023 Good morning - I think there's an easy answer to this and probably a setting I'm overlooking. Trying to drag / move a window left and using TAB move to enter distance and angle. Getting weird angles... Is there a setting to lock in the angle to "normal" angles, e.g. 15 degree increments? Thanks again, Jim Link to comment Share on other sites More sharing options...
TeaTime Posted September 8, 2023 Share Posted September 8, 2023 I'm fairly positive it's just showing the distance/angle you've moved your mouse from the original handle location. So in this instance if you'd grabbed a window handle that was on the outside edge, and dragged it over to the outside snap of the wall, it'd be -180. But for windows I don't think it matters since they can't be pulled out of a wall - just set the distance and it should be good. Link to comment Share on other sites More sharing options...
JKEdmo Posted September 8, 2023 Author Share Posted September 8, 2023 58 minutes ago, TeaTime said: just set the distance and it should be good. Thanks TT, I think a wonky angle does affect distance. Here's a test door. I move it 18" left with angle not corrected: The result is not a true 18" move: For other objects like bathtubs, lines, text, etc., the tab move angle is orthogonal... So, behavior between objects seems inconsistent to me unless there is some deeper "Chief logic" I don't understand. (This being entirely possible and the reason I use this forum!) Jim Link to comment Share on other sites More sharing options...
TeaTime Posted September 8, 2023 Share Posted September 8, 2023 Oh! Huh. Yeah most things in chief like to move orthogonally, and the Enter Coords dialog tracks the objects movement, but not windows. I guess I've never noticed the difference. But I don't think there's any override, probably just something their engineers should look at fixing. Link to comment Share on other sites More sharing options...
JKEdmo Posted September 8, 2023 Author Share Posted September 8, 2023 14 minutes ago, TeaTime said: But I don't think there's any override, probably just something their engineers should look at fixing. Thanks for your insight TT. Jim Link to comment Share on other sites More sharing options...
glennw Posted September 9, 2023 Share Posted September 9, 2023 Open Preferences>Edit>Behaviors>Primary Movement Method>check Polar. Back in plan view select the window and drag it along the wall. As you drag, have a look at the status bar and note the distance moved and the angle. Keep the drag angle the same as the wall angle. Use TAB and then check the angle - it should be the same as you saw in the status bar. Link to comment Share on other sites More sharing options...
