todd3drhd Posted September 1, 2023 Share Posted September 1, 2023 Hello everyone, I hope someone has had the same experience that I have been having. For starters let me say that I am working in X13. I have the X14 update downloaded and will be getting the X15, but my computer cannot handle these later versions. I am still trying to Render with the CPU. I am getting a lot of light bleeding into the rendering. The light is coming from nowhere. Mostly on rooms that have exterior walls, but the light is not coming through from non-connected walls or ceilings that I can see. Has anyone had this issue and if so, what was the solution (X13). Todd B. Link to comment Share on other sites More sharing options...
Dominic900 Posted September 1, 2023 Share Posted September 1, 2023 Hello Todd, Have you put on a roof as that may help with the light bleeding. I used to use CPU Raytracing before upgrading my computer anyway that should help by putting on a roof. That's what I did and that helped a little bit with light bleeding. Also have you let it render more that 100 passes? If I recall correctly you have to give it more time for the image to improve. Please let me know if that helped you. Thanks. Also enjoy your long three day weekend. :-) Dominic Link to comment Share on other sites More sharing options...
GeneDavis Posted September 2, 2023 Share Posted September 2, 2023 A roof for sure, lower the sun intensity to something like 8,000 for starters, and add more interior lights. Link to comment Share on other sites More sharing options...
todd3drhd Posted September 16, 2023 Author Share Posted September 16, 2023 I have and always have roofs on my projects prior to rendering. I have tried placing many lights and increasing the light data. None of this helps. Link to comment Share on other sites More sharing options...
ericepv Posted September 17, 2023 Share Posted September 17, 2023 It would be easier to determine the problem if you post your plan. Link to comment Share on other sites More sharing options...
TJDDesigns Posted September 18, 2023 Share Posted September 18, 2023 If I remember correctly, you also should have a foundation on the plan in addition to the roof. It helped me with light bleed issues in the past when I was using X13 & X14. Hope this helps. Link to comment Share on other sites More sharing options...
