JKEdmo Posted August 17, 2023 Share Posted August 17, 2023 Good morning, I'm drawing my CAD property lines and would like to have zero angle minutes displayed. Right now they are suppressed. I can't figure out where the setting might be. Thanks again for any help. Jim Link to comment Share on other sites More sharing options...
Solution TeaTime Posted August 17, 2023 Solution Share Posted August 17, 2023 Might be wrong but I don't think there is an option or preference for that -- I've only ever seen it simplify. Draw a straight line and it'll show N90E, rather than N90 0' 0"E. Link to comment Share on other sites More sharing options...
Chopsaw Posted August 17, 2023 Share Posted August 17, 2023 23 minutes ago, JKEdmo said: I can't figure out where the setting might be. No CA setting for that. It can be done with a very complex macro and referenced line label. Link to comment Share on other sites More sharing options...
JKEdmo Posted August 17, 2023 Author Share Posted August 17, 2023 17 minutes ago, TeaTime said: Might be wrong but I don't think there is an option or preference for that Thanks. Total bummer. Not end of the world though. 4 minutes ago, Chopsaw said: No CA setting for that. Thanks! - Jim Link to comment Share on other sites More sharing options...
Chopsaw Posted August 17, 2023 Share Posted August 17, 2023 6 minutes ago, JKEdmo said: Thanks. Total bummer. Not end of the world though. There are also plenty of other formatting options that can be accomplished with macro's depending on the region you are working in and the timeframe the survey was done and sometimes even the personal style of the individual surveyor. Trailing zero's is a common modern one to confirm the level of accuracy used in doing the survey. Link to comment Share on other sites More sharing options...
JKEdmo Posted August 17, 2023 Author Share Posted August 17, 2023 9 minutes ago, Chopsaw said: Trailing zero's is a common modern one to confirm the level of accuracy used in doing the survey. I sent Chief a suggestion to allow trailing zeroes. My very first quarter of college in 1986 I had a surveying class. We had to be in the sheep fields at around 7 AM in the morning with the steel tape. I may still be suffering survey trauma. Link to comment Share on other sites More sharing options...
