JKEdmo Posted August 16, 2023 Share Posted August 16, 2023 How do you all usually model wall pilasters / bump-outs on a framed wall? Thanks, Jim Link to comment Share on other sites More sharing options...
joey_martin Posted August 17, 2023 Share Posted August 17, 2023 You can create a wall break and thicken the wall in those locations for a quick way to create those. If for a remodel, I generally like to know how those are build though and model that way. Are the furred or extra framed walls, or larger framing members? Link to comment Share on other sites More sharing options...
JKEdmo Posted August 17, 2023 Author Share Posted August 17, 2023 3 hours ago, joey_martin said: You can create a wall break and thicken the wall in those locations for a quick way to create those. Thanks Joey. That's kind of the way I've been doing it, or as individual chases. I was wondering if there was a method I was overlooking. 3 hours ago, joey_martin said: Are the furred or extra framed walls, or larger framing members? Dunno. Just working of a supplied plan. Not able to visit site. Link to comment Share on other sites More sharing options...
DRAWZILLA Posted August 18, 2023 Share Posted August 18, 2023 You can also use a double 2x4 stud wall designed as a single wall and use a niche for the opening in the wall Link to comment Share on other sites More sharing options...
JKEdmo Posted August 18, 2023 Author Share Posted August 18, 2023 1 hour ago, DRAWZILLA said: 2x4 stud wall designed as a single wall and use a niche Interesting approach. I have not used the niche tool yet. I will try it out. Thanks again, Jim Link to comment Share on other sites More sharing options...
