Wall Framing not generating
Migaloo
  On 8/7/2023 at 6:45 PM, Migaloo said:
My little storage areas will not generate in framing.
Expand
Not sure exactly what you want, but the Wall Type definition had no framing specified in those pony walls. I specified framing for the lower wall but not the upper since it has cast iron (?) as the main layer.
The settings are kinda messed up, had to fix some stuff. Is this what you're after?
2040504531_ScreenShot2023-08-07at3_14_05PM.thumb.png.d2a7c409c573cbf9e952db785c3e28c7.png
Classic mistake: You checked Framing on the B&B layer:
Be sure you select the Framing layer and set it to generate framing
Once checked, make sure spacing/width are set right, or default
Did the same thing on the Brick-4 wall type.
