kwhitt Posted August 2, 2023 Share Posted August 2, 2023 Ever since updating V15 in the last couple of days, the glow has stopped working on this particular symbol - see images and symbol attached. The "white lighting" on other symbols works okay. Anyone have any ideas on how to fix? Untitled 1.calibz Link to comment Share on other sites More sharing options...
kwhitt Posted August 2, 2023 Author Share Posted August 2, 2023 You can see the glow when the camera is perfectly perpendicular to the symbol but not at glancing angles. Weird, as I've been using this symbol without any issues for over a year. Link to comment Share on other sites More sharing options...
TeaTime Posted August 2, 2023 Share Posted August 2, 2023 The little touch buttons in the lower left go in and out as well. This looks like classic "z fighting" to me, chief often has issues when two surfaces are right ontop of one another. I'm actually less surprised that it's happening and more shocked it hadn't been happening all along. But if it was fine in X15 before this last update, then maybe something they fixed ended up breaking this - you should probably send it to support. 1 Link to comment Share on other sites More sharing options...
Kbird1 Posted August 3, 2023 Share Posted August 3, 2023 4 hours ago, kwhitt said: Ever since updating V15 in the last couple of days, the glow has stopped working on this particular symbol - see images and symbol attached. The "white lighting" on other symbols works okay. Anyone have any ideas on how to fix? Untitled 1.calibz 119.67 kB · 3 downloads I think there was a fix for Mirrors in the last update? and you can see the LED, if you turn off Reflections in the Camera Settings, it seems to be work here with Reflections OFF anyway so it might need to goto support for a Fix ? On....... Off....... Mick. 1 Link to comment Share on other sites More sharing options...
kwhitt Posted August 5, 2023 Author Share Posted August 5, 2023 On 8/2/2023 at 7:21 PM, TeaTime said: The little touch buttons in the lower left go in and out as well. This looks like classic "z fighting" to me, chief often has issues when two surfaces are right ontop of one another. I'm actually less surprised that it's happening and more shocked it hadn't been happening all along. But if it was fine in X15 before this last update, then maybe something they fixed ended up breaking this - you should probably send it to support. Teatime - thanks for the reply. I apologize for the long delay. I was not notified as I usually am that I had a response. It's not Z-fighting as the light strip and control button are offset enough to avoid this. Link to comment Share on other sites More sharing options...
kwhitt Posted August 5, 2023 Author Share Posted August 5, 2023 On 8/2/2023 at 9:23 PM, Kbird1 said: I think there was a fix for Mirrors in the last update? and you can see the LED, if you turn off Reflections in the Camera Settings, it seems to be work here with Reflections OFF anyway so it might need to goto support for a Fix ? On....... Off....... Mick. Hey Mick. Sorry for the delay in replying. Here again, I had no idea there was a reply. I think this may be a bug which I will now report. I've been using this model for at least a year with no problems. Link to comment Share on other sites More sharing options...
Kbird1 Posted August 5, 2023 Share Posted August 5, 2023 8 minutes ago, kwhitt said: Hey Mick. Sorry for the delay in replying. Here again, I had no idea there was a reply. I think this may be a bug which I will now report. I've been using this model for at least a year with no problems. Check the Latest Updates PDF, I am sure there was mention of a Mirror Reflection Issue that was "Fixed" which may mean it has broken you symbol ? Rob posted a link here to the PDF......... https://chieftalk.chiefarchitect.com/topic/39624-new-update-to-x15/?do=findComment&comment=298450 Mick Link to comment Share on other sites More sharing options...
kwhitt Posted August 5, 2023 Author Share Posted August 5, 2023 2 minutes ago, Kbird1 said: Check the Latest Updates PDF, I am sure there was mention of a Mirror Reflection Issue that was "Fixed" which may mean it has broken you symbol ? Mick Thanks Mick. I updated a day ago and just tried the symbol. It still doesn't work. I just reported it to Chief. Link to comment Share on other sites More sharing options...
Kbird1 Posted August 5, 2023 Share Posted August 5, 2023 Just now, kwhitt said: Thanks Mick. I updated a day ago and just tried the symbol. It still doesn't work. I just reported it to Chief. I meant the Fix had broken your symbol , I thought you were already on .X15.xxxx.77 PDF linked above now......... M. Link to comment Share on other sites More sharing options...
kwhitt Posted August 5, 2023 Author Share Posted August 5, 2023 4 minutes ago, Kbird1 said: I meant the Fix had broken your symbol , I thought you were already on .X15.xxxx.77 PDF linked above now......... M. Got you! I was out of town this week working from my laptop and just updated my workstation at home. Had I thought about it before updating the workstation this morning, I should have checked the symbol prior to doing so. I'll report back on what Chief has to say... Link to comment Share on other sites More sharing options...
