DefinedDesign Posted July 25, 2023 Share Posted July 25, 2023 Perplexed as to why I can see the Deck Framing, Posts, and Concrete Footings on the back deck but not on the front deck in this cross section - any solutions are greatly appreciated. Note: Using X12. Link to comment Share on other sites More sharing options...
Solution KenL-sdd Posted July 25, 2023 Solution Share Posted July 25, 2023 You may need to reframe the front porch. Posting your plan would help us to help you. Link to comment Share on other sites More sharing options...
DefinedDesign Posted July 25, 2023 Author Share Posted July 25, 2023 2 hours ago, KenL-sdd said: You may need to reframe the front porch. Thank you! This worked. It took me a while to figure out how to reframe the porch but I stumbled across this icon. In plan view >Select the Room >Select Build Deck Framing Icon Link to comment Share on other sites More sharing options...
DBCooper Posted July 25, 2023 Share Posted July 25, 2023 If you open the deck room and make sure "auto rebuild deck framing" is turned on, then you shouldn't have to rebuild it every time you make a change. Can't remember if X12 had any bugs where you needed to force a manual rebuild even when it was turned on, but I know this has happened to me before (but it's been a while). 1 1 Link to comment Share on other sites More sharing options...
DefinedDesign Posted August 3, 2023 Author Share Posted August 3, 2023 On 7/25/2023 at 7:54 PM, DBCooper said: If you open the deck room and make sure "auto rebuild deck framing" is turned on, then you shouldn't have to rebuild it every time you make a change. Can't remember if X12 had any bugs where you needed to force a manual rebuild even when it was turned on, but I know this has happened to me before (but it's been a while). Thanks! Link to comment Share on other sites More sharing options...
