DefinedDesign Posted June 30, 2023 Share Posted June 30, 2023 Using X12 with a double pony wall and while in the wall dialog box, it seems it would be efficient to put this picture in the layout page for the HVAC, Plumbing, Electrical trades to see. Is there a way do this? I realize there may not be a way to locate the actual image generating in the dialog box, but curious if there is a way in the 3D rendering to do this? The simplicity of seeing only the wall and from the perspective shown below really helped the HVAC expert to understand the construction of this wall. Link to comment Share on other sites More sharing options...
Solution DBCooper Posted June 30, 2023 Solution Share Posted June 30, 2023 Draw the wall all by itself in a blank plan. Create a vector camera view. Send to layout. 1 Link to comment Share on other sites More sharing options...
glennw Posted June 30, 2023 Share Posted June 30, 2023 Do a screen capture (Shift+4+Command and drag a window) and then Import Picture. Have a look at the various options here: https://support.apple.com/en-au/HT201361 1 Link to comment Share on other sites More sharing options...
